Old January 3rd 2005, 00:36
Rhino1XL Rhino1XL is offline
Which One???
IF you had a choice to build a great handling and great riding GL Super...... would you pick a 73 or a 74???
(I'm in California, and I don't want anything newer than a 74 for SMOG reasons)
Thanks !!!!!!!!!!!!!!!!
Old January 3rd 2005, 00:49
74 with the steering fron a 75-up
Old January 3rd 2005, 11:39
A 73 would also work with the 75 and up rack and pinion steering...just make sure that it is the latter 73 with the 2 bolt struts, not the earlier struts like on a 71 - 72 super.
How come you can use a 75? It is 2005 now, so it it would be 30 years old this year...
Old January 3rd 2005, 17:34
VWader04's Avatar
VWader04 VWader04 is offline
i was also wondering if the rack and pinion setup would work...can it be swapped into a 74.
does the rack and pinion offer any advantages to lowering/handling
i have not seen the suspension layout for it..can you go lower with the rnp?..considering the pitman arm on the 74!
Old January 3rd 2005, 17:42
VWader04's Avatar
just noticed post in suspension section :whoops:
Old January 3rd 2005, 18:25
I believe the 71 or 71 suspensions can go the lowest.... not sure about the difference between 73-74 and the 75's with R&P...
Old January 5th 2005, 12:46
kdanie kdanie is offline
They changed the smog law last year, no more rolling 30 year exemption.
We are stuck at '73 until the democrats roll it back to an even earlier year.... The law does not specify a year as I understand it and they can change it anytime they want to now. They really want us to stop driving our old cars!! I'll be moving out of this state as soon as I get my daughter through school.
ken
Old January 5th 2005, 18:15
1 of the 1001 reasons I don't live in Cali. Great place to visit
Old January 6th 2005, 00:08
73notch's Avatar
73notch 73notch is offline
i could have sworn gov. swarzenegger stopped the smog exemption 30 year rule at 1976.
www.subynotch.com
Old January 7th 2005, 19:28
YEAH.... I thought that the 30 year rule applied to 76 and newer as well!!
Old January 9th 2005, 01:27
VWader04's Avatar
Beginning April 1, 2005, the 30-year rolling exemption will be repealed. Instead, vehicles 1975 model-year and older will be exempt. Therefore, 1976 model-year and newer vehicles will continue to be subject to biennial inspection indefinitely.
quoted from www.smogcheck.ca.gov
Old January 10th 2005, 00:04
THANKS VWader !!!!
