Old January 6th 2005, 00:48
Pillow's Avatar
Pillow Pillow is offline
Anyone running late 944 single pot fronts?
Hopefully a simple question.
Most people are using the early 944 single pots with the back mounted rotor on the hub. No problem.
I have a later '87 944S front setup that uses the same early caliper but with "hat" style front mounted rotors. This elliminates the need to remove the hub when changing rotors, good.
The rotor offset to the caliper mount seems to be the same, but just want to verify this before commiting to this setup over the traditional early setup.
FWIW I have two sets, but like the front load rotor much better than the rear trapped setup.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
