Old January 8th 2005, 02:40
randyj randyj is offline
Where to buy 1986 944T caliper rebulid kit?
Where can you find rebuild kits for 1986 Porsche 944 Turbo Brembo calipers?
Randy
Old January 8th 2005, 10:18
haven't looked, but Pelican Parts is sure to have them. if not, i always see some up on ebay. lastly try Ian at 944online.com.
Old January 9th 2005, 20:43
Pelican Parts has the following listed:
Sorry, but as of right now, there are no rebuild kits available for the 944 Turbo or 968 calipers.
I have not seen any on Ebay for the last year.
Randy
Old January 10th 2005, 01:55
jrinlv jrinlv is offline
I'm pretty sure that if you look on pep boys or auto zones web site that they say you can order kits through them, and they are options in the search...I have not "talked" to anyone about ordering them. So you know JR
Old January 11th 2005, 13:00
Have you contacted Brembo?
63 356b time capsule
948 project
Old January 12th 2005, 12:12
SteveStromberg's Avatar
SteveStromberg SteveStromberg is offline
Brake seals for Porsche turbo brakes are sold by the seal you will need to buy 4 seals for each caliper. The seals will cost about $16 each. The last one I supplied was about 6 months ago so the cost could be more.
Contact KC at McKenna porsche he can help you with the seals.
Old January 14th 2005, 16:52
MattKab's Avatar
MattKab MattKab is offline
Steve, how easy do the steel bolts that join the caliper halves come out of the Aluminium? Is there a gasket between the two halves?
I'd like to renew my seals if I can get them.
Matt
Old June 25th 2008, 22:31
vwdevotee
PepBoys lists them for about $12 per caliper. This is just for the seals though, not including the pistons.
Old June 26th 2008, 20:51
You sure they are for brembo 4 piston calipers?
Old June 26th 2008, 21:44
vwdevotee
Yeah, I was really shocked too. I asked specifically if that was per piston, and he said "no, for all four in one caliper". He still could have had no idea what he was talking about though.
Old June 27th 2008, 21:18
...for $12 buck's each it's worth a look. (compared to $45 each w/piston)
Old August 26th 2008, 03:13
Clatter Clatter is offline
In a daring longshot, I went to Pep Boys.
You are right, they have no idea what they are talking about...
Anybody know how to get ahold of Brembo?
How about just carefully levering out a few seals, and getting a (good) parts jockey to measure and match?
There HAS to be another car out there that has the same seal dimensions....
