Old January 14th 2005, 09:55
Coilovers
Besides Kerscher,Topline and CSP, which other companies make good coilovers for 02/03? I understand H&R has ceased their 03 product! Any from KAW or KW? Also saw coilovers from feine-cabrios too. I have Kerscher with koni yellows top ajustables and want to try others but if possible a better setup.
T4 2666 1303s
Old January 14th 2005, 11:16
wasn't there a company in the UK called RedLine 9 or something like that making kits?
Old January 14th 2005, 13:11
Yes, Machine 7 advertises them in VolksWorld. I never investigated that option, though, so I can be of no further help.
Old January 14th 2005, 17:10
MattKab's Avatar
MattKab MattKab is offline
M7 resells Kerscher struts.
Kerscher used to supply H&R struts before switching to the awesome Koni/Eibach/struts..You want more SilverBullet? I'm happy with mine.
Red9 Design coil-overs are substitutes for torsion bars and they sell joggled spring-plates.
Leda will make struts to your spec, anything goes.. external damper adjust, spherical end bearings, not cheap but not too common either.
Matt
Old January 15th 2005, 05:42
Thanks guys for the replies. My konis are leaking so since got to replace them, might try something else but if nothing better, just the absorbers then. Waiting for remmele's web to be on-line, they say by Jan.
T4 2666 1303s
Old January 15th 2005, 11:23
bigwindow bigwindow is offline
I am pretty sure KW is making them for 03\02..
I think a company called feine cabrios or memminger cabrios or something, sell them!
1963 Germanlooker projekt
1969 T-1 daily driver
Old January 16th 2005, 05:09
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
coilover
www.feine-cabrio.de..
