Old January 1st 1970, 00:00
jakriz jakriz is offline
Questions about jakrizs ride
Maltese Falcon Racing
http://www.superbeetlesonly.com/foru...y&cmd=sc&cat=6
Old July 22nd 2003, 09:28
Thanks for sharing your ride with us. Its one bad bug!
2 questions: Could you explain how you pressurise the engine bay, and, I was wondering about your choice of a 73mm crank. Thats not one of the "usual" sizes.
Ron
Old July 22nd 2003, 11:26
Ron, i wrote the article about Jak's car. And if I remember correctly, the pressurized effect in the engine bay takes place because he is running a Porsche style wing that allows air to be forced into the engine compartment.
Jak, if I am wrong about this, please let me know
Old August 8th 2003, 08:52
Thats exactly right Joe, I also don't use the the fron breast plate between the engine & the fire wall so as to get even more air into the engine bay. The only downside is that after a day on the track the engine bay gets a little dustier than normal.
The crank is a custom crank, only a few were made in Australia.
regards
Jak
Old December 24th 2003, 02:00
jmillheiser jmillheiser is offline
there is another way to get a 73mm stroker crank.
take a 69mm VW journal crank and have it offset ground to chevy/buick journals
Old December 24th 2003, 03:31
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Why not use a more conventional crank (size that is) that is more readily available? I would like to know if it was an attempt to make an engine more 'square' or what?
Thanks in advance.
