Old January 22nd 2005, 16:17
roscoe roscoe is offline
Unhappy 1303 3 bolt to 2 bolt strut swap?
can you swap the 2 bolt 1303s strut set up onto an older 1303 3 bolt drum set up? because i have sourced the bits including the bottom arms as i have heard it might be easier to swap bits around to 944 brakes, golf mk1 coilovers (cheapest way forward at the min) or does anyone convert your old struts to coilovers- chop off bottom cup and replace with threaded sleeve and platform? Please help me
Old January 22nd 2005, 22:34
petevw's Avatar
petevw petevw is offline
i'm sure you can, quite a few have done this. i've kept my 3-bolt struts using toplines adjustable struts.
'72 super
'65 bus
'52 split
Old January 24th 2005, 12:12
Chris Percival's Avatar
Should be a straight swap, you need struts, hubs, track control arms and anti-roll bar (sway bar).
Old January 24th 2005, 21:39
Superman
Originally Posted by Chris Percival
you need struts, hubs, track control arms and sway bar
That's correct.
