Old January 22nd 2005, 17:15
vennard vennard is offline
oil gauges
What would be the correct range on an oil temp and pressure gauge? I have been offered a pressure gauge of 0-5 bar and a temp gauge that goes up to 150 celcius. not sure what that is in psi and farenhieght.
Cheers Karl
Old January 23rd 2005, 03:08
I have the same press and temp range gauges in my car.
5 bar = 73 psi
150 deg C = 302 deg F
If they are VDO guages the standard senders (80 psi and 300 deg) will work.
