Old February 16th 2005, 04:51
Camber adjustment
Any way of adjusting camber on the rear of an irs bug? Besides raising the rear? I have early 944turbo alu. arms and my rear camber is -4!!
T4 2666 1303s
Old February 16th 2005, 11:14
Search and you shall find ...
http://www.germanlook.com/Forums/sho...ber+wide+tires
Old February 17th 2005, 08:27
Rotating the outer part of the control arm from the spring plate by loosening the 3 bolts, would alter ride height IMO. Nobody mentioned this aspect tho or is it non-existant?
Old February 17th 2005, 10:13
For the amount of rotating I did, I could not measure any appreciable difference ... maybe 4-5mm drop at the most.
