Old February 19th 2005, 21:52
onixbonilla's Avatar
onixbonilla onixbonilla is offline
Calling Sandeep/Camber adjusting
Hi Sandeep!
Will like to know how much do you notched the spring plates to get a correct rear camber on your car. From the readings on the forums I understand that the notching/filing should be done toward the upper part of the spring plates two rear holes, so the trailing arms rotate upward.The front hole should be left intact? Am I correct?
Mine have MBT spring plates, Remmele/Bilstein coilovers,on late 951 aluminum trailing arms.
Onix
