Old February 23rd 2005, 05:30
bugman78 bugman78 is offline
1303 to 1302 suspension swap
I have read that if you install a 1303 front susepension into a 1302 it will increase the track by 26mm. Is this per side?
I have a 78 super with rack n pinion and would like to put the 1302 suspension in. Is this possible?
The reason I am considering this is so I can decrease the track width so I can tuck my 42mm offset wheels in the fenders. I talked to John at Topline and he said I had to use at least a 55mm offset to tuck. I am hoping that i can decrease my track by 26mm per side.
If possible would it be a direct bolt in?
What is needed to accomplish this?
Old February 23rd 2005, 08:47
Chris Percival's Avatar
Yes, you can swap the 1303 for 1302 stuff. You will need the struts, hubs, track control arms, and anti-roll bar. However I havn't heard of the track width change before. Might be worth asking over at www.superbeetlesonly.com first.
Old February 23rd 2005, 08:59
Ive heard the track width increase was 10mm per side between
the 02's & the 03's
Old March 4th 2005, 00:59
Superman
It is a 7 mm difference
Old March 4th 2005, 20:28
Diego74 Diego74 is offline
ive heard the same about width diffrence I also read it somewhere I think it was in hot vws were they showed how to stuff fat wheels under your super
Old May 16th 2005, 09:48
dgluyas's Avatar
dgluyas dgluyas is offline
TURBO 944 SPINDLE to 1303 STRUT MOUNT
I wanted to use the 1987 944t spindle on my superbug 1303. The holes in the spindle are the same distance apart yet seem to be on a different angle ? ANY SUGGESTIONS
"Goliath"
Old May 19th 2005, 03:54
Superman
That spindle is very different (although it looks simular) to the 1303, it's won't just "bolt up". I have detailed information in the brakes forum, please use that thread.
Old May 19th 2005, 03:56
Superman
Okay, just to clear things up here (because 26, 10, & 7mm has been referenced in this topic)...
7mm = difference between track width of 1302 and 1303
10mm = addition of track width, per side front, when adding 944 brakes
26mm = addition of track width, per side rear, when adding 944 brakes
