Old October 23rd 2002, 19:09
danielzink's Avatar
anyone look at BJ spindles for the 944 conversion ?
Hey all,
Just wondering if anyone has looked at the ball joint spindles to see if a 944T or 993 brake upgrade would be possible ?
Dan
65 notch 2300cc type4
www.danielzink.com
Old October 23rd 2002, 19:24
Alex's Avatar
Alex Alex is offline
Dan,
in the brake gallery you will see a B/J spindle with a cailper adapter for 993 Twin Turbp calipers. I aslo did a 944T conversion with stock B/J spindles. You can see that in the brake article.
Even the CB dropped spindle requires modification so there is really no big difference. It will work with stock spindles.
You have to make a bracket for the stock spindles and a spacer for the CB spindle for 944 Turbo brakes. You need brackets or adapters with both if you want to install 993 calipers.
