Old February 26th 2005, 16:43
beet beet is offline
Thumbs up 944T 1987 front hubs in a SB spindle
I have two fronts hubs from a 87 944T.
I want to use it in my 1302 (brake disc) spindles. I can see I need two bearings spacers, one for the big bearing and the other for the small bearing.
It´s no problem, but the distance from the hub to the spindle is 1 milimeter or less.
It will be work good?? or I must do other bearing spacer to separate the hub from spindle??
see photos, ( i don´t have the bearing spacers yet)
