Old March 4th 2005, 00:30
Uber Affe's Avatar
Does anyone know if it's possible?
Would it be possible to adapt this to a 1303 dash?
http://cgi.ebay.com/ebaymotors/ws/eB...957654640&rd=1
And the next question. Yes, I know ANYTHING is possible, but is it worth the trouble?
How EASY would it be?
I'm not lazy, but I'm no engineer either.
Old March 4th 2005, 00:33
Superman
The 1303 dash is metal underneath so you could adapt almost anything and then have it recovered.
Old March 4th 2005, 02:15
Uber Affe's Avatar
hmmm....
What about the electronics part of it?
I have no doubt I could figure a way to makit fit, but what problems would I have adapting the guages to the 1303 w/ a stock engine?
Old March 4th 2005, 12:30
A friend of mine has a 126 series merc and the oil gauges are mechanical, and the speedo drives from the transmission. the tacho is from the 15 terminal of the coil though. from what i know instruments light in yellow.... and the tacho is up to 6k rpm... i dont know if thats enough for you, but its not for me...
Personal thought is that i wouldnt go for it. to merc style for me...
Chris
Aircooled 4ever
1973 1303 going towards GL
Old March 6th 2005, 04:14
it said the bidding has ended for that item....did you buy it?
Well....it looks do-able, and the thing is...you could always change out the gauges if you have too many problems with them!
VolkSport Kfer Gruppe
www.VolkSport.net
