Old March 5th 2005, 21:40
flat flat is offline
Mazda RX7 brakes
I've had this project on the back burner for quite a while. Finally got around to designing the hub. Uses 3rd gen RX7 rotor (294x22) and 2nd gen 4 piston aluminum caliper. The good think about the RX7 rotor is that it has a large diameter to give sufficient brake torque, yet isn't as thick and heavy as the P-car stuff. See here for pics:
http://www.vdubcustoms.com/Wedo/mazdabrakes.htm
The kit will be bolt on to stock drum, cb drum or stock super spindles.
I'll post the caliper bracket as I get it manufactured.
Easy,
www.vdubengineering.com
Old April 3rd 2005, 22:23
I posted some more pictures of the kit. The pics show the caliper placement aswell as the caliper bracket.
Easy,
Old April 27th 2005, 13:38
gcmarchi gcmarchi is offline
Lanner,
Can the hubs (and rotors) be supplied with a different bolt pattern (5 x 4.75")? This setup is just what I have been waiting for but what about rears? Are you going to do a similar Mazda based set?
Old April 27th 2005, 23:11
Yup,
I can machine the hubs for any bolt pattern. The downside is that the rotor needs modification and that is no problem if you purchase pre-modofied rotors from me. The problem arises when you have to replace the rotor....time to find a machine shop. I can make up a jig so that you can drill the rotors on a regular drill press if you wish.
As for the rear, the RX7 ebrake actuation cable faces the wrong way when adapting to a T1. It can be done but requires a weird lever 'see-saw' which seems a little exotic. Nothing is impossible, but sometimes I have to evaluate whether the effort matches the reward.
Easy,
Old May 14th 2005, 11:34
martilo's Avatar
martilo martilo is offline
Hi Lanner,
so what do you propose to match the mazda's bolting pattern in the rear (with e brake)?
Don't you have another killer app for the rear in the work?
Also, can you supply your front mazda kit complete with the calipers?
Also, what master cyl can be fitted with these without reinventing the whole car?
Thanks for your lights bud!
Louis
ps: its a shame nobody wrote the "fitting big brakes for dummy" yet...
Old May 14th 2005, 19:39
rip's Avatar
rip rip is offline
well if you get a CB rear disc brake kit you can order them with out a pattern and then have them drilled. I don't know if Lanner has come up with a rear kit yet, shouldn't be hard though either way.
I have the Rx7 kit and that's what I planned on doing.
Rip
