Old March 15th 2005, 20:49
996 front brake calipers...
I just recieved my front brake calipers in today and noticed that there is a sensor or something like that attached to the brake pads....I would like to keep the pads that are on there now bacause they're almost brand new! i there a way I could either get rid of these sensors or is there a parts I can order allowing me to put the sensors to use?
VolkSport Kfer Gruppe
www.VolkSport.net
Old March 15th 2005, 20:54
airwerksvw airwerksvw is offline
Could that be a temp sensor for disabling traction control? I know some cars have it but i'm not sure of the sensors typical location.
Old March 16th 2005, 01:52
I think it may be just a wear indicator, perhaps when the pads wear down and make contact it lets the computer know that pads are shot?
Old March 16th 2005, 03:17
tom'72's Avatar
tom'72 tom'72 is offline
My thoughts also
Old March 16th 2005, 15:40
not sure, but most likely. my 951 calipers had the same in stock form.
Old March 17th 2005, 00:08
Well...Im gonna look into it, might try e-mailing the company i got them from, they're a dismanteling yard and so i figure they might know a little about it. Thanks anyways guys. :agree:
www.VolkSport.net
Old March 17th 2005, 18:55
justdubbin's Avatar
John, I have got 2004 996 Turbo calipers and the front brakes has got the sensor you mention, it is as a few people think a wear indicator.
I will be using it as soon as I get them fitted....... eventually
Rob.
Old March 17th 2005, 22:19
Thaks man...so are you using the sensor or ??? if you are using the sensor where and what do I need? I'd like to keep the sensor if I can...that'd be sweet, a brake pad sensor in my car
www.VolkSport.net
Old March 17th 2005, 22:26
craazy Cooter's Avatar
The sensor just grounds a light on the dash. Tons of high end european cars have them.
Old March 19th 2005, 18:14
Jim Hunter Jim Hunter is offline
Exclamation
Brake pad wear indicator was nothing to worry about you can remove it entirely with a medium flat screwdriver.
Old March 19th 2005, 19:03
justdubbin's Avatar
Like CC says it's just a ground, have an ignition live to your dash light and the earth to the sensor, when the pads wear down the sensor shorts out completing the circuit.
Rob.
Old March 24th 2005, 01:35
Oh...ok. Thanks for the help there guys!
www.VolkSport.net
