Old March 18th 2005, 14:19
tom'72's Avatar
tom'72 tom'72 is offline
911 brakes mounted...
Took me half a day but there almost ready to hook up to the brake lines.
Vented discs with 4 pot Brembo calipers.
Old March 18th 2005, 14:20
tom'72's Avatar
they will be good company for soon to be put in 280hp engine
Old March 19th 2005, 19:14
justdubbin's Avatar
Tom, I see that the hubs you are using mean that you will use wheel bolts as opposed to studs and lug nuts, what hub assemble did you use to achieve this?
Rob.
Old March 20th 2005, 09:04
tom'72's Avatar
rather difficult to explain in my "bad' English but I think what you refer to is the plate on the disc where the wheel bolts on.
I bought the kit like this from someone that had adapted it for a superbug and the inner part of the hub is a VW piece attached to the porsche hub/disc
