Old March 21st 2005, 22:34
Uber Affe's Avatar
Racing Shifter position?
I'm a little confused.
I was looking at the interior photos section and came across two people with the same style ($700 shifter) the racing looking one w/ the metal box
and both of them have the shifter mounted in two different positions.
Is one of them mounted backwards or does it not matter?
What is the "correct" way or are they from two different sources (manufacturers) and are they actually each mounted correctly?
Old April 5th 2005, 18:34
rip's Avatar
rip rip is offline
yea looking at the pics I really don't know how the shifters work, are they cable?
because with the universal joints there it just seems a little complex.
Old April 12th 2005, 08:48
Andy's Avatar
Andy Andy is offline
I have just bought one, the spring should be located towards the back of the car.
The cable is for reverse gear engagement.
1973 German Look 1303S
Imperial Blue.
ORL 801M
Old April 14th 2005, 02:56
Andy's Avatar
If the gear stickis not mounted the correct way around, the reverse lockout will not finction correctly.
One problem that I encoutered with the gearstick cage is that its very close to the handbrake lever. You may have a problem(I find it awkward) pressing the button when the handbrake is fully up. I bent the handbrake lever slightly so that it now moves up and down between driver's seat and gear stick cradle.
Imperial Blue.
ORL 801M
