Old March 27th 2005, 19:18
Troy_Audio's Avatar
No Oil Pressor...
Hey ..
Iv just had my motor running long enuff to check the guages..
Fuel Press is holding at: 4.6lbs
Oil: -N/A- My Guage has power & the sender wire is hooked up.. Maybe bad new sencer?
Things Im Checking on..
Pull Valve Cover To see if it has oil..
Recheck sender & wires..
What all can you think of..
the motor ran fin before the overhall.
I changed the valve covers,header/exhaust,Carbs,fan,alt,tins,wiring
ign system,fuel system,pully system
>>1st Time Running Video<<
Thanks N Advance
Peace Troy
Old March 27th 2005, 19:37
Mikey's Avatar
Mikey Mikey is offline
for your oil pressure gauge, are you useing a special sender or the stock sender? The stock sender isn't made for a gauge, only to make a light in the dash go out when there is pressure, Just to be courius, is the engine/transmission grounded to the frame?
Mike
'04 R32 Tornado Red
Old March 27th 2005, 21:39
Troy_Audio's Avatar
I checked the covers..
they had oil in'em i found a small leak by the oil fill/breather
Bottom edge leaks(Drip drip drip) 6" marking over night
I will check into my wiring & sender when I get back toit
Peace VDubz 4 Life c(<>_<>)0 |,,|_
Old March 27th 2005, 21:40
Troy_Audio's Avatar
I just looked i dont see a ground strap on the block.. but Maybe on the tranz.. Need to jack it up..
Old March 27th 2005, 22:29
Mikey's Avatar
if you're using solid mounts or you didn't take the tranny out, it should be there.
Mike
'04 R32 Tornado Red
Old April 4th 2005, 10:57
vwboy72bug vwboy72bug is offline
if your running a full flow setup try taking the line off the pump cover, pour some oil down it, then try starting it. mine doesn't like to prime after a build and that always works for me. btw- leave the line hooked to the pump cover itself, unhook it from the other end
Old April 4th 2005, 23:18
Troy_Audio's Avatar
Im not full flow yet..
But i will keep that inmind for after I do..
Iv been looking for leaks & found a few..
Dip-Stick,Alt Stand,Filler/breather on the mounting spot..
I think (As stated)My Oil Press maybe for a Light only..
But its running ok for now..
lil timming & carb tuning then i should be ok..
Peace Troy
