Old March 30th 2005, 18:03
purplebug purplebug is offline
urgent help on offset needed
Come on guys, someone can surely help me! I have chance of 17"x7 wheels with 4x100pcd and 45mm offset. i've already got discs/drums redrilled to suit and maxx struts (for three bolt type) will be bought soon. Will these wheels be ok in arch/fenders!
please help
Old March 30th 2005, 21:51
should be OK. most run 50+ offset so you may be close to the fender, but the right tire selection may help you there too.
Old March 30th 2005, 22:16
Don't rims with a 50 offset require spacers?? To get it closer to fender because there is so much offset, i.e. closer to the strut. From what i understand, a rim with a 35-40 offset can go on the front of a super beetle with out spacers. With a 45, you might be ok, but I would call topline and ask some questions. If you do need spacers, you may need longer studs, depending on the need for spacers.
=EuroLook71=
71' Super Beetle
