Old April 1st 2005, 16:55
VKG site blogs
hey VKG guys. in an effort to get the blogs rolling on the VKG site and to have some place for car specs, i have added a blog for each of you (or most of you at this point, i still have some more to do). in your blog i already made one post that will have your car specs like the old site. all you have to do is open that post and hit the edit icon. once in there you will see the places in the code to add the info. if you hit any snags, get with me. it is pretty easy once you are looking at it though.
the downside is that as soon as you start posting to your blog for project build info, etc, that post moves down the list. i will come up with a better way to do this at some point, but this will have to do for now. the idea was to make it something you can maintain to save me some time.
again, let me know if you have any problems. we need to get some content on that site to make it worth visiting. that is on you guys to do.
Old April 1st 2005, 17:01
oh and if you want to change the pic i put in there or if you need to add one, all you do is go to you gallery, open the pic you want, right-click and hit properties. in the prop window, triple-click the location/URL and right-click then copy. that copies the location of the image to your clipboard. go back to your blog, edit the post and in the beginning code where you see "img src=", paste the content from your clipboard into that field where you already see a URL (or inbetween the quotes ("") if you don't have an image already).
if i didn't create a blog for you and you want to take it on, just copy all of the code out of someone else's first post in their blog and copy it into your post.
Old April 1st 2005, 18:38
Mikey's Avatar
Mikey Mikey is offline
Cool beans, I like what you're doing.
Thanks for all the hard work. :bowdown: You Da Man!!
I know you're far from finished, but when I look at the list of blogs to edit mine, there is no edit icon on the right, like the galleries have. Hope it helps. :agree:
Mike
'04 R32 Tornado Red
Old April 1st 2005, 18:47
are you logged into the site? you have to be to edit the blogs. if you are and still don't see it, let me know as that means i have permissions screwed up.
Old April 1st 2005, 20:32
I logged in and still don't have any editing tools on my blog.
Old April 1st 2005, 21:04
i just found out the problem. you don't see it because i created the blog. i will be removing all of them and you will have to create it yourself. i will post some instructions here is a few.
Old April 1st 2005, 21:12
OK. Here are the instructions for creating your blog.
  1. Go to the blog section and click "create a new blog".
  2. Enter a title and description.
  3. Leave all of the checkboxes as is.
  4. click "show categories".
  5. click "Member Rides".
  6. click the checkbox next to "categorize this object".
  7. click "save".
  8. go to the list of blogs and to the right of yours you should see some icons. click the paper and pencil one to create new post in your blog.
  9. no title needed. just paste the code below into the "Data" field and edit it as noted above for your pic and text info.
Old April 1st 2005, 21:30
Mikey's Avatar
YAY, I did it. Before I didn't have the "create/edit blog" when I was logged in, now I do.
Mike
'04 R32 Tornado Red
Old April 5th 2005, 00:12
Thanks for the info there zen, I had been meaning to get ahold of you to find out what to do....though Im waiting to post when I get a camera...should bee soon I hope! (I think I said that before)
VolkSport Kfer Gruppe
www.VolkSport.net
Old April 7th 2005, 23:43
yellow73's Avatar
yellow73 yellow73 is offline
Thanks for all your work with this Zen. I will try to get this done when I am next at a computer with some time.
73 Type 1 - 2270 Type IV
64 Type 34 - 1500 Type III
