Old April 19th 2005, 21:11
vdubdude1969 vdubdude1969 is offline
a bigger engine like a 2007cc!!!
i got a 1776cc engine right now and i want more power so i heard you can put a bigger crank in it like a 78mm crank and it will make it a 2007cc and i know i would need to machine the case to fit it but what eles would i need to do to it. thanx alot
Old May 11th 2005, 06:40
Ashraf Ashraf is offline
crank
thats about the only thing you gonna need to do.......
but you might as well got for a 82mm stroke..cause in a few months you gonna wish you had out one on.
the ammount of torque it makes is unbelievable.
Old May 20th 2005, 03:45
4agedub's Avatar
4agedub 4agedub is offline
I'm currently building a 2007cc with the following specs:
78mm scat crank
calillo rods
90.5 mahle pistons
scat c55 cam
twin 44idf webers
fully worked heads
I will most probably finish assembling her this weekend and maybe start her in a week or 2.... will let you know how she runs
