Old May 3rd 2005, 09:29
cormac163 cormac163 is offline
1303 to 1303S
I am about to order a set of 1303s spindles to upgrade my '75 1303 to a 1303S Stylee. I am also going to get the Tarox 6 pot brakes as I had them on my last 1303S and they are brilliant.
Is it a straight swap on the two bolt system? or do i need different tie rods etc.
thanks in advance
Old May 19th 2005, 03:50
Superman
If I read your question correctly, you're going to change from 1303 drum spindles to 1303S disc spindles... use the same tie rods/ends.
Old May 19th 2005, 06:02
1303s
Thanks Superman.
do you know what parts i can use? are the backing plates calliper and the discs all a straight swap with the discs?
Old May 19th 2005, 09:12
Superman
Yes, you will just need to remove the drum, backing plate, and spindle then install the disc spindle and it's associated disc and backing plate. The disc and bearings are the same as the Bug and Ghia but the backing plate and spindle are unique to the Super.
