Old May 7th 2005, 14:46
motormike40 motormike40 is offline
90 hp obtainable from a 1600?
I am looking for 90 hp from my 1600. My plan is go get my heads both intake and exhaust ports ported, then put in a 1:4 ratio roller rockers arms, steel valves, hi rev springs, merged header with a fatboy muffler, and dual Kardons? What will my numbers look like, and is with worth my time and money?
Old May 7th 2005, 18:59
Danborn's Avatar
Danborn Danborn is offline
In order to get 90hp I think you need an other camshaft and two double cabs. Even higher, comp 8.5 to 9.5-1. I’ll estimate your configuration to make 70-75hp…
Jesper
Old June 6th 2005, 18:39
southysuper's Avatar
southysuper southysuper is offline
Smile
It's possible to get over 100 from a 1600, but that's in race trim and build only for race. In other words, a disposable engine. High comp, aggressive cam, you name it. I think you can make a more durable for the HP 1776 than you can a 1600. If you want to make 100hp stock, go for a type 4 engine. Best of luck!
Old June 20th 2006, 01:52
cpgn0805's Avatar
cpgn0805 cpgn0805 is offline
48´s + counterweight 69, fk45 + 8:1 compression + header + polish heads 40 x35
I hope 90 Hp.
CARLOS PALOMINO
Pics from the best 1600cc aircooled in Perú
http://static.flickr.com/53/165440766_0db3562c33_b.jpg
http://static.flickr.com/54/165432955_089c9be899_b.jpg
<a href="http://www.flickr.com/photos/cpalomino/165440766/" title="Photo Sharing"><img src="http://static.flickr.com/53/165440766_0db3562c33_b.jpg" width="1024" height="686" alt="Renzo en la balanza 890 kpk" /></a>
<a href="http://www.flickr.com/photos/cpalomino/165432955/" title="Photo Sharing"><img src="http://static.flickr.com/54/165432955_089c9be899_b.jpg" width="1024" height="712" alt="Partida 11 de Junio LAS PALMAS" /></a>
