Old May 16th 2005, 22:09
LLVWGL LLVWGL is offline
Question Do you need super disc spindles for 944 n/a brakes?
Is a disc brake spindle nessicary for 944 n/a front disc brakes?
Has anyone fabbed a caliper bracket for a drum 1303?
Please point me in the right direction.
thanks
Nick
73 1303
Old May 19th 2005, 03:58
Superman
You'll just use the 944 spindle.
Old May 19th 2005, 21:32
well, I cant really because I have an early 1303 with 1302 front end.
Old May 19th 2005, 23:17
oicdn's Avatar
oicdn oicdn is offline
Question is, is if you can use NA hubs for Turbo brakes.....
I would assume you could use the drum ones as the Vdub customs' kit for supers used stock spindles and supers have drums up front.....my guess.....
Old May 20th 2005, 02:24
Superman
You need to put the 1303 suspension in your car and then the 944 brakes. I had to do that to mine.
Superman
No, the hubs/discs have a different offset where they mount together.
Old May 20th 2005, 03:10
I'll probabaly have the hubs machined, since it would save me from having to buy new struts/springs/sway bars and all of that other junk i have under there.
