Old May 17th 2005, 14:28
Troy_Audio's Avatar
How To Select A Cam &...
Hey Guys
Im woundering How Should I select a Cam for my Motor..
I have a 1835cc
Due Dell 34's(45's By Summers End)
CB 041 Heads
It has a Egl 110 in it now..
What is the 1st thing i need to look at before buying a new cam..
Also Looking to Add Some Pauter roller rockers How Do I match this up with what Im getting..
I want to do it all at 1 time..
Full Flow,Cam,Rockers,Carbs... & ?¿?¿
what else should I look at?
Thanks Troy
Old May 17th 2005, 16:17
starmember's Avatar
i like to have some more info. is it a daily driver or just for fun or a full race car and where would you have the most power low-mid or high.
peter
90 in to te corner.
Old May 17th 2005, 19:21
Troy_Audio's Avatar
Hey Peter
I plan on driving to shows & Hit some Twisties..
Im not sure if I can Say it right..
I may just keep making it Bigger & Bigger Till I dont have much left..
I will be driving the Bug for a few yrs But will Go Race Ready After I get My Next GL project..
What Kinda Power Can I xpect from my 1835cc?
Would Like a Driveable But thats about it..
I like to Smoke My tires & Blaze the turns..
Need more info.. ¿
Peace Troy
Old May 18th 2005, 03:15
Ashraf Ashraf is offline
hi ....what sizes are you carbs and valves.....cause i had 2 1835cc motors.
one had (40 by 35.5 valves ) with 36 weber downdrafts and a engle 120 cam......and 2nd motor had same heads with 125 engle......
both went very well ....
125 made mor power on top....
120 cool allround cam..
Old May 18th 2005, 12:55
starmember's Avatar
so you u are a weekend driver. but where you want the most power.
if you install te 45 dell you are in the mid - high range rpm
if you want the most power in the mid range then you should take the E 110
and if you want the most power in the high range you should take the E 120
Be sure you DONT OVERCAM that would realy decrease hp and tork and longevity
90 in to te corner.
Old May 20th 2005, 00:32
Troy_Audio's Avatar
Right on guys I still got some time before I get all my parts & service..
so I will try to drive my car a bit to see what I am looking for..
I would like to smoke tires & power out of turns..
I could go with Dell 40's or 45's
Im not much of a drag guy but it is fun..
long drives.. not sure yet..
Need to be more intutch with my car before I do a distance drive..
Peace Troy
Old May 20th 2005, 03:05
starmember's Avatar
If you go with the 40 then you could get te E 110 but you will have low end power.
90 in to te corner.
Old May 21st 2005, 11:44
Troy_Audio's Avatar
Thanks again for all the info..
I found an OLD Schooler Porsche guy & he will be helping me select the right stuff..
Looks like he is on the lines of what your saying..
40's the 110..
May find a non Egl cam that is kinda in the mid of the 110/120
He also dose custom grind so I will keep you posted..
Peace Troy
Old February 5th 2006, 02:10
Bebobug's Avatar
Bebobug Bebobug is offline
Question
How much are those roller rockers?
