Old May 19th 2005, 13:25
Pyrorocketeer Pyrorocketeer is offline
Sound Deadener...?
I am almost at the point where I can start putting down sound dampner, and while I was searching online for a good product, I came across these spray on sound deadeners that would work great for my car. My only problem is if this stuff works as good as the sheets that you lay down. So has anyone used any spray on sound deadener like "lizard skin" or "eDead v3"?
Does this stuff work as well as the sheets, or not?
Chris Rhine
Old May 19th 2005, 22:27
Dasdubber's Avatar
I can't comment for sure as I haven't done a comparison between spray on vs sheets. I have used stinger roadkill expert and dynamat extreme throughout my car so far:
I'd suggest looking up some car audio forums (eg. caraudio.com, sounddomain.com, caraudioaustralia.com/forums etc) and do a search there as the car audio guys will have a much greater knowledge of such products and may have done some comparisons.
Old May 20th 2005, 00:42
Troy_Audio's Avatar
If you set on a spray or roll on I would Go with http://www.b-quiet.com/index.html
Other that Iv used..
http://www.fatmat.com/
http://www.madmat.net/
http://www.secondskinaudio.com/
For Behind Your Speakers..
http://www.madisound.com/cgi-bin/ind....16480&pid=311
For Your Home Audio System..
http://www.madisound.com/bk16.html
Peace Troy
Old May 20th 2005, 06:06
rustbucket's Avatar
I've used eDead in my car. Works great. Easy to apply etc... And for $50 you get enough to do the entire car with about 3 coats.
It's YELLOW
Rolling on a daily basis.
