Old May 21st 2005, 03:41
PaulKoutsoukis PaulKoutsoukis is offline
modded Super suspension idea.
Would it be advantageous to add a third member to the strut suspension of a 1303? What I mean is, since I'm thinking of fabbing up a lower control arm from tubing (to accomodate porsche ball joints and possibly some camber adjustability), wouldn't it make sense to triangulate it and attach it with a bushed fitting to the front framehead? I haven't really thought this out yet (or even looked at my car for that matter), but wouldn't it make sense? Most modern strut suspensions I've seen utilize a lower control arm with two frame mounts, gotta be an improvement in stiffness at least.
I'm sure someone with more subject knowledge has a better idea about this?
Old May 21st 2005, 07:46
This has been done before, a search should fidn some pics or maybe in the gallery. The J sports bug definitely had this done...
Old May 21st 2005, 17:23
judgie's Avatar
judgie judgie is offline
the j-sport car has this.i'm thinking of going this route so i can also get castor adjustment.
cheers rob
Old May 21st 2005, 17:46
Mikey's Avatar
Mikey Mikey is offline
I believe that yetibone would be able to help with this. Check out this thread to see his progress on this.
http://www.germanlook.com/Forums/showthread.php?t=5536
Mike
'04 R32 Tornado Red
Old May 22nd 2005, 17:58
Jeza Jeza is offline
A freind of mine s1fter (who occasionally visits here) has done this to his 1302.
He remade the lower arm, but turned it into an A arm, with rose joints at all corners to adjust camber and caster etc.
Hope this sparks off a few ideas for you.
Cheers
Jeremy
1302 RAt "GermanLook"
Old May 30th 2005, 02:38
Excellent, thanks for the info gentlemen.
