Hi guys please go easy on me, but I would like to know how to fit early 944 single pot brakes to a 1978 1303 (front and rears)
I've read afew web sites which tell you how to fit them early beam axles but not 03's.Thanks people.
Hello blueeyes
There are a lot of links to search on this forum (use the search function at the top of the page) but here are a couple that I think will help the most http://www.germanlook.com/Forums/sho...&highlight=944 and http://www.germanlook.com/Forums/sho...&highlight=944 The trap for young players is that the track increases both front and rear- the rear guards can still usually cope with the increase but if you keep the standard guards you'll need to carefully research your wheel selection for the front to fit (the ideal offset is the later Porsche offset of 52- 55 mm). The other trap is that the camber on the Porsche spindles is more positive than the Beetle spindle- so you will probably need either the H&R camber bolt http://www.germanlook.com/Forums/sho...ighlight=H%26R and or the Topline camber plus control arm bush. Your may need new tie rods (this is model dependant and you may get away with out changing them on your model) and/ or you may need to change which way they fit to the spindle (anti bump steer kit). Good Luck Cheers Jeremy
1302 RAt "GermanLook" |
