Old June 13th 2005, 11:17
Murfman Murfman is offline
1st post phone dial question
I found a set of 16 x 7 phone dials from a 928, they are a 65mm offset will these work on my 71 Super or do I need the 53mm? Thanks in advance. Murfman
Soon to be German looker!
Old June 13th 2005, 12:53
Good Question...
First off, I wasnt aware there was a 65mm offset in the 16 x 7 Phones???
Well, if there is, here is what you need to know...
I had a 71 Super and I had to run narrow struts/springs (80mm, stock is 120).
I ran 17 x 7 et55 wheels and had to run a 10mm spacer to get the wheels
off of the springs. This is not an issue on the later supers as they have a 10mm
per side wider track width. Nor is this an issue is you are converting to 944
brakes, because depending on the method, you track width will increse as well. I was running the stock drums, redrilled to the Porsche pattern.
You would need to run a narrowed strut/spring and a 20mm spacer to use
those wheels. This is of course if you are running the stock drums in the
front, the spacer will get smaller if you are changing to Porsche brakes.
Old June 13th 2005, 15:34
Originally Posted by vujade
Good Question...
The Wheels are off of a 1985 Euro 928s. I was planning on using the CB brake setup drilled to the Porsche pattern. Thanks Murf
Old August 9th 2005, 22:34
Pillow's Avatar
Pillow Pillow is offline
The good thing about Phones is that there are lots of options
You could run the 65mm offsets in the rear and then get a narrower wheel in the front to minimize clearance issues. Like a 16x6 53et or 15x6 53et.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
