Old June 13th 2005, 13:51
4pumpedCL 4pumpedCL is offline
Anyone know what's necessary to mate Type4 CVs and axles with a Type1 IRS tranny?
Does anyone know what parts or modifications are necessary to install type4 CV joins and axles and a Type1 IRS tranny? Thank you in advance.
-Aaron
Old June 13th 2005, 16:18
MattKab's Avatar
MattKab MattKab is offline
The original Porsche 944 CV boots have a VW 411 part number so all you will need is T181 output flanges.
Matt
MattKab's Avatar
And welcome to GL.com
Old June 22nd 2005, 07:36
Are type 4 CVs the same as Kombi ones? The way to fit kombi ones is to get the correct 181 output flanges and 181 or 944 axles. If the Type CV shafts are longer than a Beetle, use your Beetle CV shafts, have centre section of the back of the CV section counter bored down a bit until the CV can slide onto the Beetle shaft enough.
