Old June 18th 2005, 15:39
purplebug purplebug is offline
Slimline coilovers, who's best?
I've got my 17"'s, disc conversion and new rear drums drilled 4x100. What are the recommendations for slimline struts? I've been looking at kerscher(machine7) £440 for fronts only Laperformance can do them £350, don't know what type? or maxx topline's?
Any advise is appreciated
Old June 18th 2005, 23:58
effvee effvee is offline
Thumbs up Depends
Hi, it would depend on if you Super is a 1302/flat windshield or 1303 curved windshield. In the case of flat windshield you can lower the body approx 5 inches. The curved windshield will lower approw 3.5 inches. Noe take in account what type of rims you will use, and the rim offset. Another varable is if you use a 944 disc brake convesion and the width increse. I not sure but I beleive all of the struts won't have camber adjustment at the strut, only at the lower control arm. So as you can see a little more infor is needed. But if we can help we will.
Well after all of the above I see you will use disc/drum conversion. So offset will still need to be factored in issue and 1302 veses 1303
Old June 19th 2005, 07:45
LAP's struts are AVOs, I went for the kerschers in the end, direct from Germany as M7 didn't have any in stock. They have a slotted top hole for camber adjustment and have koni adjustable inserts with progressive eibach springs.
On my late cab, the track seems quite wide, I am running at least a degree negative camber to get the stock ATS wheels under the front wings, pulling in the control arm will bring things to about right I think, I'll probably get a more adjustable bolt.
Old June 20th 2005, 13:11
slimline coilovers
Ricola, Who did you purchase your kerschers from in germany and did you save any doing it this way? I think i'll end up going for kerscher due to all previous posts recommending them.
Old June 20th 2005, 15:16
I bought them from Kerscher direct, got shipping prices etc by email then phoned the order through with my credit card. I saved a bit, not a massive amount...
Old June 28th 2005, 02:37
1303mark 1303mark is offline
thnig is LAP only do the 2 bolt later 1303 struts, Machine 7 do the early ones and late ones, so if you are pre74 you are faced with only the kersher, or change you whole setup to take later struts.
i have kersher, and the car is lowered to the max, only 3" ground clearance on the framehead,
i dont have wings on yet so this may not really be reasonable, but i did find that the steering arms will hit the body so you may need a bumpsteer kit like i do.
