Old June 22nd 2005, 10:39
Uber Affe's Avatar
Hood Pins...Where to place them?
Some of you may have read my insane rant on the 1303 hood hinge fiasco...
I now need to plac some hood pins at the window side of my bug to keep the damn thing on and to keep my paint from falling apart.
So what is the best way to mount these bad boys.
Old July 16th 2005, 04:24
Phat73VW's Avatar
Phat73VW Phat73VW is offline
I had a similar problem on my bug. The hood flew up and busted the hinges and i couldnt repair it to work right again with new hinges. so i put hood pins.
here are some pics
(please exuse the nasty trunk..these pics are 3 years old)
i made some mounting brackets for the pins out of raw steel. then drilled holes into the trunk liner lip.
here are the Sparco sliding hood pins i used
heres how the hood comes off now.
Hope this helps...sorry i didnt see the post sooner
BRIAN
Old July 16th 2005, 20:35
Uber Affe's Avatar
Later is better than not at all.
That's ok. I ended up putting them in pretty much the same place you did except I didn't end up using welded plates. I have them bolted up along the gutter where you put your plates. I have my old hood latches up front.
The way I have the latches and pins set up is actually pretty cool and the pin plates are running more horizontal with the window than the angle you have them at. I'll try to get pics up soon. It's nice to see other people wit a similar set up. I wasn't sure if I was just beinf weird w/ my idea. I'd seen them on racers, but not on any street bugs up front.
Your car looks awsome by the way.
Thanks again,
G.Sainz
Old July 16th 2005, 20:43
Uber Affe's Avatar
by the way...
What does that sticker on the window say?
Old July 17th 2005, 06:29
Phat73VW's Avatar
the sticker says "DONT TOUCH ME I'M NOT THAT KIND OF CAR"...
yeah if you can post up some pics of your setup that would be great. :agree:
BRIAN
