Old July 10th 2005, 02:33
Maximum 930 CV angle
What is the recommended maximum CV angle that can be used on 930 CVs. This is for a street driven car with around a 300 hp Subaru motor.
Old July 11th 2005, 14:53
CPRcubed CPRcubed is offline
Sorry I don't know what the spec is but unless your trailing arms are on (or past) the stops you shouldn't have a problem. Back in the 70's I ran a Baja that had 17" of ground clearance on pan (arms on the stops, 30" tires) with stock 69 CV's.
1970 VW (Stock & Rusted for now), 1994 F350 CC DRW 7.3L PSD, 1971 25 ft Airstream Trailer
Old July 11th 2005, 20:17
Perhaps I should make a better explanation of what Im doing. Im fitting a WRX motor to my bug along with a G50 transmission. I want to move the transmission forward so that the motor has a better fit, the motors are extremly wide at the cam covers and as a Beetle engine bay tapers, the more forward the better it is for me and also for better weight distribution. By doing this I will need to angle the the axles forward to from the trailing arm to the gearbox, I want to know what the maximum safe angle is.
Old January 19th 2006, 19:08
JiI's Avatar
JiI JiI is offline
weight transfer
I'm planning a very similar thing to your idea. I'll be running a 915 tranny with a subie and plan on moving the whole thing forward for better balance. I'll probably chop out the center of the torsion housing or fab up all new rear suspension. Probably going to run 930s as well just to play it safe.
Drop me some pics if you feel like it.
Jeff
"If at first you don't succeed, give up, there's no sense in making a fool of yourself."
Old January 19th 2006, 19:35
Panelfantastic's Avatar
CV info here .
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old January 23rd 2006, 22:26
airwerksvw airwerksvw is offline
I see the link gives info for max angle, but it seems to be on one plane. What happens when you run them at compound angles? IE tranny is forward 3" and up 2"?
