Old July 19th 2005, 01:23
Uber Affe's Avatar
Any Air Conditioning Options?
I live in Texas...where a heater is about as useless as a third nipple.
Don't ask.
An A/C, however; is another story entirely.
You can almost bet that you will be dehydrated by the third stop light you reach and dead by the fourth.
With that said...
Any cooling options (human cooling-not engine) for a bug that doesn't delve into one of those $1200 kits? or drain power from the engine?
Something along the lines of an EberSpacher only for cold instead of hot?
I've looked into those swamp coolers and other related marine/tent/rv coolers,
but I have been told that the humidity index is too high here. That may be true of PART of the year, but not all and I've even seen folks use electric fans in their buggies. So...
Any ideas form all you smart GL'rs?
UA
Old July 19th 2005, 18:11
randyj randyj is offline
Uber Affe,
You are right. Here in Texas you have to have air conditioning. Especially for you in San Antonio or me here in Austin. Both of us are too close to the coast for the for the humidity to be below 40% except for a couple of times a year. You are going to have to bite the bullet and spend the money for a quality air conditioning system.
For me I am trying to decide between a system from Vintage Air or upgrade the system that came with my 75 Super Beetle to R32.
The Vintage Air system coupled with a Eberspacher "http://www.espar.com/htm/Specs/water/D4Wspec.htm" or Webatso coolant/water heater will give me cold air, heat and last but not least De-humidified Defroster. The problem is that I will have to move my gas tank to be able to install the evaporator/blower.
With the dealer installed system that came with my 75 Super Beetle, every thing but the evaporator and condensor will have to be upgraded and replaced. I also will not have the De-humidified Defroster option. But every thing will fit without any cutting!
I will let you know which direction I go.
Old July 25th 2005, 23:43
Uber Affe's Avatar
Talked to my dad...
He says he's looking at modding a honda civic AC system to his bug.
Or maybe he meant CRX??
Probably the latter.
At any rate. I'll let him guinea pig his car first and see what happens. Last thing I heard was he found one for $100 form some kid who ditched it form his ricer.
I also gave him a perfectly functional compressor from a Volvo to mess with.
We shall see!!!
Old July 26th 2005, 01:57
Aparently the Toyota Prius have a electriclay driven compressor, would be great on a bug with limited room.
Old July 29th 2005, 08:58
from what i heard, Filmore Enterprises makes a great VW a/c unit. never used one though.
Old November 18th 2005, 03:26
krems krems is offline
interesting option....no?
alternative to AC
