Old July 27th 2005, 01:10
airwerksvw airwerksvw is offline
2275 shortblock or parts for sale
I decided to go subaru on my oval, so my 2275 needs to be sold. I assembled it, but it has never been in a car. I would like to sell the whole engine and give someone a good deal on a shortblock, but if I don't get any responses I will piece it out. Entire setup is balanced. Everything is new except the case and heads.(case has not been ran since machined)
Specs are:
Rimco machined case, 94 bore / full flow / clearanced for 82 stroke / line bore. Includes chromoly 10mm headstuds 375.00
Cima "B" pistons / cylinders NEW 150.00
Scat 82mm 4340 crank w/ wedgemated 12lb. flywheel and Scat chromoly gland nut <rod journals were turned .010 due to minor surface rust when in storage before assembly> Included is matching set of Kolbenschmidt bearings and scat straight cuts 450.00
Scat 5.4" H-beam rods w/ARP bolts, 200.00
6 puck kennedy disc and stage II pressure plate , both new 100.00
HD aluminum pushrods, uncut 30.00
Pauter 1.5 roller rockers 275.00
CB performance drysump oil pump, 65.00
Web 86a on 112 l.c. 50.00
Scat lube a lobe lifters, 35.00
040 welded heads, dual springs, very nice portwork, 42 x 37 valves -used- 200.00
I would like to sell the whole setup, so I will give it a couple of days at the whole engine for 1800.00 before I part it out. I would also be willing to work with installing a different cam if desired
Old August 1st 2005, 22:01
Engine is sold.
Thanks Tom
