Old July 28th 2005, 22:25
flat flat is offline
S4 Brake Setup
I've got a line on some Audi S4 (from a '00 or '01 car) front brakes. They are the dual piston sliding caliper style. The calipers are HUGE and use 4 (8?) pads per caliper. They use 323 x 30 rotors.
I can adapt these brakes to a Beetle, KG , T3 or Bus. Basically, I'll build to suit to your specs (offset, bolt pattern etc). The Audi pattern is 5-112mm but it can be easily adapted to 5-100mm. Roughly, they can be setup for an offset of +.125" per side or greater.
I'm thinking $C850 for the whole setup (billet hubs, caliper brackets, calipers, used turned rotors,new pads and all required hardware.) They will take a stock beetle brake hose.
Anyone interested? I'll only build the setup is I have a customer for it. I'll post pics soon.
Easy,
www.vdubengineering.com
Old August 1st 2005, 21:21
Here's a pic of the goods. The calipers take 4 pads per side, and the piston size is 43mm each.
Someone's gotta want these. I'm kinda itching to get working on these, but it's a waste of my time and money if I don't already have a customer lined up.
