Old July 29th 2005, 02:30
lazylongboarder's Avatar
Lightbulb My own front end coilover setup.
I just bought some through rods intended for offroad use for $50, and was wondering what the specs are on the Red9 setup:
Spring Outside diameter?
Compression length?
Extended length?
Shock housing diameter?
Spring Rate?
I think this would help out us guys in the U.S. where the red9 setup would be a little pricey to bring over to American soil. Also I would like to have a 4 way adjustable setup: Spring rate, Compression valving, Rebound valving, and ride height. And I heard the quality of the Red9 shock is'nt up to par, thats how they can sell it for 450 for the whole shabangabang.
The Varishock, and Aldan Coilovers are the biggest canidates as some of you read on my previous posts that the Ohlins TTX44 are $3099 EACH! My price range is from $500-$1000 per pair.
I talked to Jeff the head Bilstein Rep and he suggested a 36 mm midget shock with an add on coil over sleeve kit. This would be an excellent setup for someone who wants to spend $250 on their front suspension and still get the best without the external adjustments (Besides ride height). Why Doesn't Bilstein have an externally adjustable shock besides the PSS9!!!???
1974 type 1
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old July 29th 2005, 10:28
GS guy GS guy is offline
LLB - NADA(!) on the Aldan or Varishock on a ball-joint beam. No way those big 2.5" springs will work up next to the shock tower - or the trailing arms.
I've found (2) possible candidates for the small body front shocks needed. These will accept smaller OD 1.9"(ID) springs - AVO (England):
http://www.avouk.com/pm/12
(They have a US distributor BTW, the sell the Stalker/Lotus-7 replica)
and here in the US - ARS:
http://www.advancedracingsusp.com/shocks/1000.htm
How are you planning to secure the trailing arms from side to side movement? The only thing I've seen is an internal bushing like the Red-9 set-up, or external bushing like the Formula Vee guys use. The external looks more reliable, but don't like that there's no type of grease seal.
Jeff
Old July 29th 2005, 11:13
Don't overlook the QA1's PromaStars. These are a quality rebuildable unit. I bought mine from a husband/wife shop http://www.naake.com/ . I chose them because they are so helpful and I had remarkably quick service. These people KNOW shocks. Call them and see what they think about the shocks available for the $.
