Old August 2nd 2005, 08:01
rustbucket's Avatar
Pistons for T4
Okay, I'm hoping some of you T4 junkies will jump in with some direct experience. I'm going to have my 1.8L jugs bored for 96mm pistons to build a 1911cc engine. Which pistons should I use? Some considerations:
1. I want reliability.
2. A normal compression ratio ~8.5:1
3. Nothing unobtainable.
4. I plan on using stock rods.
It looks like I can fairly easily get my hands on Keith Black's, AA's, and maybe a few others.
It's YELLOW
Rolling on a daily basis.
Old August 2nd 2005, 17:17
cnavarro's Avatar
cnavarro cnavarro is offline
Get some KB's and make sure to verify that the proper piston/cylinder clearance is maintained.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Old August 10th 2005, 19:19
MattKab's Avatar
MattKab MattKab is offline
Charles Navarro
LN Engineering
Charles,
What would that clearence be? I mean a stock VW barrel bored for a 96mm KB pistons. Do KB pistons vary in diameter by much more than a 0.001"?
Matt
Old August 12th 2005, 02:31
Massive Type IV's Avatar
I sell the KBs with either new or bored OEM cylinders (bored OEM ROCK!) with the correct skirt clearance and plateau finishes all torque plate honed- Remove the guesswork for just a few dollars more- Its worth it.
Jake Raby
