Old August 5th 2005, 02:20
LLVWGL LLVWGL is offline
9" rear wheels fitment
Does anyone run 9" wide rear wheels? if so do you have any pictures/description of how you made them fit? Spacers, fender flares, spring plate clearance.
BTW: i have porsche Cup II 17x9 ET55?
Old August 5th 2005, 12:48
oicdn's Avatar
oicdn oicdn is offline
Search around. I'm putting 10" 47et rims on mine. I'm needing a 10mm spacer and 2inch fenders. Sandeep has the same set-up....
Umm...but yeah, search through, there are a ton of threads about wheel fitment, and there's even a sticky at the top of this forum....
Old August 6th 2005, 03:10
I have 17x9 et 48 at the rear with 86 944turbo aluminium arms with 993 C2 rotors with 60mm widered fenders. The tyres are 255/40/17 and has bout 25mm clearance between top edge of tyre to the fender. Hope it helps.
T4 2666 1303s
Old August 7th 2005, 04:21
thanks for the info, I suppose I'll look around a little better.
