Old August 23rd 2005, 18:52
oicdn's Avatar
oicdn oicdn is offline
86 944 rear rotor size???
Curious...on Vdubcustoms website...it goes 83-85 na....then 87+Turbo....
What is the size of an 86 944T rear disc rotor? Do I just use an 83-85 NA rear rotor?
I'm finishing up my brakes and need rear rotors. I was actually thinking of buying a complete set of X-drilled or slotted rotors, but considering I have 87 fronts, I'm kinda mismatching a bit here....so I'll just wait till I need new ones considering the front pads and rotors are still in GREAT condition...why buy new ones, when they work fine????
Anybody know the size???
Old August 24th 2005, 03:47
86 944 turbo rear are 24mm thick and 299mm diameter, same as some 928 and 996 (which is why I used them). They bolt straight up to the early 944 rear trailing arms as they have the correct bell depth.
Old August 24th 2005, 07:05
oicdn's Avatar
Wait a second, so the rear brake rotors are as large as the 87 Turbo fronts?????
87 Turbo fronts are 299 mm. I know you obviouslt can't use an 87 Turbo front disc on the rear(or can you????) but damn...same size eh????
Old August 24th 2005, 11:12
strange isn't it. On the early 944 the fronts are actually smaller than the rears!
Old August 24th 2005, 22:25
Superman
The front brakes are smaller in diameter than the rear brakes but the fronts are much thicker.
