Old September 20th 2005, 11:17
Beetle08 Beetle08 is offline
Smile FS Porsche 914/Type 4 Motor 2300cc $4800
This motor is brand new; built by Jerry and the Crew at Northwest Connecting Rod Services in Seattle, WA. These guys have an excellent reputation for building top notch motors. The motor is new and has never been installed. Very strong motor with gobs of torque. I have never installed this motor and I am selling it due to new baby on its way.
The engine specifications are as follows:
Total displacement is 2300cc
Type 4 Case machined to accept a 911 Fan Assembly (Sharpbuilt, BAS, GWD or others can be used with the exception of the FAT Performance kit) or you can cap it off and use it stock on any 914 or type 4 based application.
96mm Wiseco Forged Pistons with Teflon Coated Skirts
Total Seal Rings
Black High Temp Coated Cylinders with ¼ inch Spacers
78mm Counterweighted Full Circle Crankshaft
Web 163 Camshaft with 284° duration and .5 lift
Web Lifters
Balanced Shot Pinged Connecting Rods
Porsche 914 3-Stud Cylinder Heads with New Sodium filled exhaust valves and Breather Tube welded on Head Assembly
3 Angled Valve Job
Compression: 9.1:1
All Internal Rotational Items have been balanced and blueprinted
CB Performance Products Dry Sump Pump (conventional pump can be used) has been installed since photo
Balanced 228mm Type 4 Flywheel (Will mate up with Type1 transmission) or replace Flywheel for 914 setup
Motor is currently set up for remote oil cooler, but stock oil cooler can be installed.
Please note that this is for the longblock only. Fan Assembly, and Shroud are not included in sale.
Price $4800. Local pick up or buyer pays actual shipping.
Please e-mail me if you have any questions: mauriciorb@comcast.net I will post pictures in the next few days.
Mauricio R. Bendana
1974 Superbeetle German Look
1964 Beetle Stock
2001 Golf GLS 1.8T
Old September 21st 2005, 11:21
I have a link with pictures. I will upload pictures directly later today. Please let me know if you have any questions.
http://forums.pelicanparts.com/showt...hreadid=241939
Mauricio R. Bendana
1964 Beetle Stock
2001 Golf GLS 1.8T
