Old September 24th 2005, 13:56
lazylongboarder's Avatar
Chassis stiffening
I'm looking to stiffen my chassis more, has anyone cut out the pan where the body bolts onto where the heater channels are and replaced them with square tubing? I'll end up tying cage mounts to these spots as well as onto the body.
Is there a kit or anything, or should I just make it my self? It doesn't look to bad, I just don't have a bender.
If people from Utah are called "Utahns", what are people from Tampa called?
1974 type 1
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old September 25th 2005, 14:23
Eyeball Engineering
Old September 25th 2005, 16:44
libila libila is offline
^ That's very interesting. How exactly would you go about installing those? Where do they bolt in exactly?
Old September 25th 2005, 17:09
Racelook's Avatar
Racelook Racelook is offline
They bolt under the floorpans to the body. Just as usual the body is screwed to the pans, only now with the stifners within.
WIebrand
B-Extreme B-Tuning.....
Old September 26th 2005, 02:45
Floridians.
Old September 26th 2005, 08:05
DORIGTT's Avatar
DORIGTT DORIGTT is offline
With all the storms, are they called 'wet'?
