Old November 10th 2002, 15:30
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Porsche Big Red Fronts Only, New
I have one set of new in the box front Big Reds part numbers 993 351 425 10 and 993 351 426 10. They are the S4 size Big Reds. These calipers were removed from the boxes to be examined when purchased and returned to the box. They have now sat on a shelf for the last year waiting to go to work. Put them to work for $500.00 Firm.
Randy
Old November 10th 2002, 17:32
Alex's Avatar
Alex Alex is offline
I can supply brackets for standard beetle using stock B/J disk spindles if you want to get that set for your bug.
I have one set that needs the thread welded and redrilled for your application to get the spacing correct. They are made out of aluminum. Pic is in the brake gallery.
Old November 10th 2002, 22:58
SuperRSi's Avatar
adapters
I am supposed to be getting a package with the MBT kit in the mail this week for the BJ front on the Manx. (paid for 10 months ago!) I am just trying to focus on this one car and get rid of some of the stuff that was purchased to build up a Super conv for someone else. They lost interest and moved on to an Audi TT. In the process I have decided to clean out the shop of a bunch of parts that are not needed. Then I can send the money to LN Engineering or somebody like that...
Repeat after me "I am not an addict"
Randy
Old November 10th 2002, 23:03
Alex's Avatar
I am curious on how that MBT kit looks like. Take a pic and send it our way. We but it in the brake gallery. I have an extra set of Remmele brackets. If you have someone for the calipers that wants to put them on a standard bug tell him I have some brackets. Sandeep's article explains what to do to get a hub for the 993 rotors. BTw...can also be used for 996 and 986 sonce they have to be redrilled anyways.
Old November 20th 2002, 00:49
will these work with Kerscher vented disks?
just wondering?
Old November 20th 2002, 08:11
Alex's Avatar
No. It will not work.
Your Kerschers are 24 or even 22mm thick and the rotors for the 993 Big Reds are for 32mm thick. This is a "no go".
