Old September 25th 2005, 16:15
volksdragon's Avatar
Unhappy motors in but will not start *she runs now*
well i finally got my motor back in everything is hooked up as it should be.
the engine is trying to fire but sounds more like a misfire.
also the fuel line coming up from the pump has a filter half way up and the filter is only half full. i know there is gas in the carb since it will squirt out when i open the linkage all the way.
i've check my plugs wires and firing order everything seems good
the distributor is in correctly as the number 1 cylinder is at tdc when it should be
any ideas?
Old September 30th 2005, 16:06
it was probably a combination of a dirty carb and a bad dizzy.
it cleaned the carb last night and swapped in my vacum advance dizzy and what a differance.
she's running and she'll idle. i still need to make final adjustments.
