Old October 14th 2005, 19:10
VEEMAN VEEMAN is offline
Is there an DIY way to fit Kesher ball joints?
Has any one tried to fit Kersher ball joints to the later track control arms with out the use of a mandrel press. If so what way did you attempt this and with what kind of tools, equipment setup did you use?
An thoughts on this.
Cheers
VEEMAN
Old October 24th 2005, 15:38
Michael Ghia's Avatar
In a word... No. I spent a long time and huge amounts of heat just getting the old ones out and getting the new Kerscher balljoints in was only made easy by using a press.
MG
Old November 14th 2005, 15:24
MattKab's Avatar
MattKab MattKab is offline
Mine took ~8500Kgforce to press in. That's about 19,000 pounds
I've found these 17mm ball joints elsewhere I can only recommend the Kerscher 17mm B/J's tho'
Matt
Old December 7th 2005, 18:06
Thanks for the replies. Took my Kerscher ball joints to my mates workshop and it took over 4 tons of pressure to press in.
Had no problems with removing the old ball joints, just wacked with a hammer and the flew out. They looked new but could not have been fitted correctly in the first place.
Any way sorted now, thanks once more.
Cheers
VEEMAN
