Old November 4th 2005, 14:27
BigPhattyVW's Avatar
BigPhattyVW BigPhattyVW is offline
Question Hey Samcat....
First of all, congratz on a great ride. I especially like the removable rear end. I see that you have a pretty bumping sound system in your bug. How much amps total is the system eating and is your alternator powering everything ok?
Coming Soon!
86mm X 90.5mm German Look Bad *** VW
Hopefully Soon!!
Back home in Port Orchard, and saving for the Bug
Old November 4th 2005, 16:51
samcat's Avatar
samcat samcat is offline
Rockford Fosgate Power 500a2 (birth certificate lists it at 726 watts max )
Rockford Fosgate Punch 250a2 (birth certificate lists it at 331 watts max )
I run a voltmeter so I can see that everything is running as it should, and with headlights on (main beam), fog lights on (pair of 100 watt bulbs) and stereo pounding we see dips down to 13.2 volts on heavy bass lines... So yes, it copes fine Its a brand new bosch 90amp(think) alternater by the way.
CYa,
Sam C
Old November 5th 2005, 01:58
Thats really cool. It tells me that I can still have some bump in my system! By the way what size of fuse are you running to each amplifier?
Thanks for the info
Clint
Coming Soon!
Hopefully Soon!!
Old November 5th 2005, 15:52
samcat's Avatar
Thanks for the info
Clint
Cor, now your asking... Dont know without going and having a look...
As for stereo, I have previously run a steg amp with a pro-plus nemesis (at 2ohm), and that didnt cause the volts to wobble either
That was a wicked amount of power.
The steg was around 700 watts RMS, and the pro plus Nemesis... Go a look it up, heres a taster:
1200 watts RMS in two ohm
RMS current @ 2 ohm mono: 90 A
Thats RMS... Bit over double for the peak.. Think what 2400 watts into 2 subs sounds that can handle it sounds like
Was driving a pair of Cerwin Vega 12" subs, each in its own box.
That was when I was going through my loud stage, now its all about quality
CYa,
Sam C
Old November 6th 2005, 15:54
Wow
That must have been one heck of a loud phase!!! Sorry about the fuse "hide and seek" question, but that must mean that you put the correct one in since you haven't had to change one ! Now Im pretty sure the alternator will keep up!
Thanks again
Clint
Coming Soon!
Hopefully Soon!!
