Old November 9th 2005, 19:01
madpballer232 madpballer232 is offline
5 x 100 pattern drilled into stock drums
is it possible? will it fall in the stock reinforced locations. has anybody done it before?
Old November 10th 2005, 10:33
flat flat is offline
Yup, Done it. It's fine as long as you install studs and do not just drill and tap the drum.
www.vdubengineering.com
