Old November 21st 2005, 17:41
Pics of your cages
I'm looking at putting in a serious roll cage and I want to see how you guys tied in the ft/rr suspension.
Old November 21st 2005, 19:30
Racelook's Avatar
Racelook Racelook is offline
http://www.germanlook.com/Forums/sho...light=rollcage
Maybe this is what you're looking for. Do an search on this forum.
Wiebrand
B-Extreme B-Tuning.....
Old November 21st 2005, 20:29
Thanks Weibrand, I'm thinking of a similar mounting to the upper strut...mount. I'm wondering how to tie it into the upper rear shock mount and then run it across like a kafer cup brace but above the rear shelf. That way I have more room for a oil cooler.
Old November 22nd 2005, 05:35
Racelook's Avatar
If you also want to mount your rear struts on your cage. You're gonna have to make some cuts in your body. Your tubes have to go through your rearwheelarches to your strutmounts. From your strutmounts you can than make some tubing just like an normal cup-strebe.
Greetings Wiebrand
