Old November 27th 2005, 20:04
Panelfantastic's Avatar
Internal sway bar... stupid or possible?
My bus has coilovers up front. That handles the suspension. I still have a few (3) leaves in each torsion tube to connect the control arms to.
My idea is this, Take out the leaves and replace them with some solid round stock. Don't use the anchor point in the center of the beam but allow the bar in each tube to twist against the other side in cornering... this is basically what a sway bar does. I could even devise a way to preload the bar but don't think it would even be necessary.
Thoughts?
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old November 27th 2005, 20:49
petevw's Avatar
petevw petevw is offline
Would work. I believe thats what they use on the rear axles of the ION/Pursuit/Cobalt. Saw a show where they machined out the sway bar and replaced it by welding in a 3/4 piece of round stock. Weld both end it place with no preload, and you should be fine. I say go for it!
'72 super
'65 bus
'52 split
Old November 28th 2005, 04:28
That's how the type 3 anti-roll bar works, I have no idea but maybe it could be adapted for you?
Old November 28th 2005, 20:18
Panel, If I read you correctly, this system already exists. Red9design makes a coilover suspension with through-rods in the front beam. You could also buy those rods at prowlers.com for 55$.
Old November 29th 2005, 10:52
Thanks for the replies, guys!
Pete, I've been checking that show out also!
Rich, I'll prolly start from scratch since I've got a narrowed beam and am about to do some heavy fabricating on my lower control arms anyway.
Kleinporsche, I had seen the Red9 stuff but it looked like their through rods were kinda small? I'm gonna try to cram as big a piece of round bar through there as I can, with the weight of a bus and all.
Jeff-
VKG Bastage child
Old November 29th 2005, 14:49
PJL54Oval PJL54Oval is offline
Would the rod need to be tempered or made from "sping" steel? I would think a shop that can make coils could fab up the rod.
Old November 29th 2005, 15:03
Good point, did cross my mind. I was gonna ask the guys over at the local fab shop I use what they thought. They're not hot rodders like us but when it comes to deciding on use of metal and tolerences, they are slick! They always laugh at me because I waaaay over engineer everything... "is this for a bulldozer?"
For me, it can never be too strong!
Jeff-
VKG Bastage child
Old December 14th 2005, 03:52
LLVWGL LLVWGL is offline
New beetles use this type of rear suspension member also. I think that it would work out great. keep us posted.
Old December 17th 2005, 05:35
73notch's Avatar
73notch 73notch is offline
ya, type 3s use this on the upper control arms. since its basically a straight rod, i would think it would be easy to make bigger ones. but i havent had one all the way apart to see how hard it would be.
-Ryan
www.subynotch.com
Old December 25th 2005, 18:20
marco the T.S.E marco the T.S.E is offline
it won't work,
the front leaf springs do 3 things.
1 .they hold the car up in a twisting action(you can aliminate the job by having coilovers holding the car) OK.
2 thay stop the tralingarms comming out of the beam.?!?
3 thay stop the tralingarms going into the beam.?!?
(the 4 rubber rings that are on the front beam are only there as grease seals! NOT suspention bushings!! if you remove the anchor point in the center of the beam the suspention will move everywere!!!!wear out the grease seals and smash the outer barrings!!!!
good luck.
P.S put the anti-rollbar on the outside.(so you can adjust it for going around corners ,setting up the car with the the driver in the car )
Old December 31st 2005, 02:44
darren's Avatar
darren darren is offline
Excuse my ignorance but how do you tune an anti roll bar?
Dont they just bolt on?
Old December 31st 2005, 05:10
73notch's Avatar
adjustable ones have a few holes on the ends that you can bolt the link that connects to the suspension arm, the further out, the more leverage and vice versa.
www.subynotch.com
Old December 31st 2005, 11:16
Modern_manBr Modern_manBr is offline
Maybe you could use your own leaf springs (all of them), just removind the anchor point in the midle of the beam.
as for the Grease seals, you could try machinning nylon to replace them, you would solve the problem of the suspension moving.
The only way to know if it will work is trying
I´m gonna do this on my drag race beetle, but I´m a bit far of start messing around with the front suspension setup.
1959 VW Beetle Drag Racer (street legal) under construction, Stock exterior (except for wider rear fenders and bumper) 2.1 Liter ABA block, 20v Head, turbocharged
1975 VW Passat (Dasher), obvious 5 speed upgrade, 1.9 Liter 8v, carburated, turbo (under construction too) 100% street
Old December 31st 2005, 12:44
Marco, I agree with everything except #3, I'm using 1 inch round bar which is as large as will fit... it is a slip fit and will have the support of the center anchor point, it just wont be anchored. 1 inch round bar is a heck of a lot more stable than a stack of leaves, there will be very little slop.
Ordered some 1 inch 4340. Gonna do all my machining and have a local place heat treat up to spring temper. Will keep everybody posted.
Jeff-
VKG Bastage child
Old January 1st 2006, 18:30
flat flat is offline
Jeff,
I'm curious as to the reinforcing of the lower arms. Is that for the coil-overs? Any pics?
www.vdubengineering.com
