Old November 28th 2005, 17:30
Turbo Haraune's Avatar
Turbo Haraune Turbo Haraune is offline
It`s Alive
Today it came back to life with a new heart.
Fired up the scooby engine for the first time in the car!
What a feeling......
Who cares if the harness is on the outside of the car.... its running!!!!!!
Vin
Check out my project pic`s!
http://www.v-dubs.no/haraune
Old November 28th 2005, 23:20
DORIGTT's Avatar
DORIGTT DORIGTT is offline
That's it! Duct tape the harness to the car, get the wife to hold the makeshift fuel tank in place and let it rip!
Oh, make sure your policies are up to date
Old November 28th 2005, 23:49
Have a good pair of running shoes on too incase you need to do a flintstones stop! Congrats!! Must be awesome, can't wait.
Old November 29th 2005, 01:16
Mikey's Avatar
Mikey Mikey is offline
Congrats! I'm sure that's a great feeling.
Mike
'04 R32 Tornado Red
Old November 29th 2005, 02:15
73notch's Avatar
73notch 73notch is offline
hellya! another one is gunna hit the roads
www.subynotch.com
Old November 29th 2005, 03:05
judgie's Avatar
judgie judgie is offline
very cool,just been looking at the build pics,well done .
not long know until road test time
cheers rob
Old November 29th 2005, 09:40
I couldnt get your URL to work.
Old November 29th 2005, 11:13
ehhhh whats a url??? dont know computers..... sorry..
but give me a block of alu, and i will make you a part...
Old November 29th 2005, 14:27
73notch's Avatar
www.subynotch.com
Old November 29th 2005, 20:10
DORIGTT's Avatar
From the pictures on your website, it appears that your coolant tubes run through the heater channels. Is that true?
Do you have any piccies of how the other end looks?
Old November 30th 2005, 12:06
There is a couple more pics on my old website.(see below)
Yes its correct that the high pressure hydraulic hoses run trough the heater chanels. had to remove the innside of the chanel to do this.
I chose to use expensive hyd hoses due to the possibility of making sharp bends without kinking the hose. also they will not make condense.(ore break)
corrosion is not going to be a problem anyway with good inhibition with dinitrol products (aircraft stuff)
There is going to be 2 airlocks that may cause problems, but bleedvalves on top of them is going to solve this i hope. (The toyota mr2 sports car have 3 airlocks and it works fine with bleeds)
I am also going to use 2 expansion tanks. one in the front and the original subaru in the back.
Have not filled the system with water yet so i dont know if it will work.
Vin.
http://home.broadpark.no/~oharaune/Karroseri.htm
Old November 30th 2005, 20:43
Rob's Avatar
Rob Rob is offline
Sweet !
Impressive project you have going !
Rob.
Old December 1st 2005, 06:35
Lurv Lurv is offline
Turbo Haraune
how made the torsionbar substitute? don't realy know what to call them so here the pic that you have on your site...
Old December 1st 2005, 11:57
tom'72's Avatar
tom'72 tom'72 is offline
@lurve, that's called a uniball setup. Remmele in Germany makes a kit and some other shops as well but pretty expensive.
Old December 1st 2005, 12:26
Yep thats right. remmelle makes them but since they are such a unserious company that they didnt answer my requests by email, i just made them myself....
Im going to publish detailed cnc machining drawings so everybody can make them.because i think the prise they are charging is insane!!
Vin
